asia.shafran
cant remove parameter default value
Hi.
I have some parameter with a default value, and I use it in one of my dialog windows.
For some reason, the "show default value" has the default value and I can't remove it (it's gray, as you can see in the screenshot attached)
anyone know why it happened? I have other parameters with default values and i don't have this problem .
I also can't remove the default value from the parameter(The "ok" button become gray too)
any ideas?
mihai.petcu
Re: cant remove parameter default value
Most likely you have PROXY_PORT property declared in the Install Parameters page with a default value. If you change it in the Install Parameters page it will get updated in the Dialogs page as well.
asia.shafran
as I wrote, it is in Installed Parameters but the problem is when i remove the default value the "ok" button become gray so i cant save changes.
you can see it here
Screen Shot 2017-01-25 at 16.21.51.png (75.08 KiB) Viewed 12957 times
Please note this is a limitation imposed by the Windows Installer engine. All properties defined in our "Install Parameters" page will be inserted in the "Properties" table of the setup package, but the entries included in the "Properties" table cannot have an empty value.
To use a property with a default empty value you should not define it in "Install Parameters" page. Just delete the property from your control in "Dialogs" page and from "Install Parameters" page and then add it only on the desired control from "Dialogs" page. In this way you will be able to define it with an empty value.
