dlenis
Combo box value and text issue.
I've populated a combo box with the filtered results of the SqlServerBrowseOutput property. I’ve followed your instruction on populating a combo box.
http://www.advancedinstaller.com/user-g ... stbox.html
Sample combo box value/text
Value = (local)\MSSQL2016
Text= (local)\MSSQL2016 Ver: 12.0.1601.5
When selecting an item from the combo box the “text” is displayed and when the item is selected the “value” is displayed. I am assuming that is the way it is supposed to work.
The issue I’ve encountered is when selecting an item and the mouse is click outside the combo box the “text’ is displayed for the item selected. This causes the SQL validation to failed.
Selecting item:
Selecting item.png (26.16 KiB) Viewed 3284 times
Item selected
Item selected mouse click outside.png (8.95 KiB) Viewed 3284 times
Item selected when mouse click outside combo box
Item selected.png (15.95 KiB) Viewed 3284 times
Thank you,
Diego
Re: Combo box value and text issue.
Hi Diego,
I tested the scenario and, indeed, I reproduced the behavior. this seems to be an Advanced Installer issue that appears when the "Enhanced UI" feature is enabled in the "Themes", "Settings" tab. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
As a workaround, you can set the "Combo List" attribute to "True" for that combobox.
dlenis
Eusebiu,
Setting the combo list attribute to true disables the ability to manually enter a server.
Do you have an estimated time when the fix will be released?
Thank you,
Diego
Hi Diego,
I'm afraid I cannot give an ETA for now. However, we will notify you as soon as the fix will be available.
Maybe, you can disable the "Enhanced User Interface" feature from the "Themes" page, "Settings" tab if it is not especially required by other features from your package.
