jrahma
Install for all without InstallTypeDlg
How can I make sure my application will be installed for all without having to add or go through the InstallTypeDlg?
Jassim
http://www.softnames.com
Re: Install for all without InstallTypeDlg
Hi Jassim,
The application will be automatically installed for all users on the machine if the "Per-machine only (fails if user is not administrator)" option is selected in the "Installation type" combobox from the "Install Parameters" page.
jrahma
I already have that set in the Installation Parameters then why my application is now asking for administrator Privileges as you can see in the attached screenshot?
Please keep in mind that this is the normal behavior. A per-machine package will always require administrator privileges before the installation.
If you want it not to ask for administrator rights, you need to set it as a "Per-user only" package in the "Install Parameters" page.
