minnumathew
Installing pre requisites displayed during uninstall
While uninstallingg the application from control panel, its showing the status message “Installing Prerequisites”. I like to edit this message as the customers are getting confused due to this message. Can you please advice me to resolve this issue
Re: Installing pre requisites displayed during uninstall
In order to edit that message, you can go in the "ActionText" table from the "Table Editor" page and edit the "Description" column of the "AI_InstallPrerequisites" row. However, please keep in mind that the message you write there will also be used during the installation of the main package when it will install the prerequisites.
To hide that message completely during the uninstallation, you can try to set the following condition for the "AI_InstallPrerequisites" row from the "InstallUISequence" table: REMOVE <> "ALL"
