Codename K
How to make prerequisites check in the x86 registry location in 64bit computer?
I have set the installer to install "AccessDatabaseEngine_X64.exe" as prerequisite. It installs fine. But it is not detecting as installed. This is because it creates the registry entry "HKLM\SOFTWARE\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path", the x86 regitry location. But since the computer is 64bit, the installer checks it at "HKLM\SOFTWARE\WOW6432Node\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path". So it always fails.
How to set the installer to check the x86 registry location please?
K
Re: How to make prerequisites check in the x86 registry location in 64bit computer?
Please note that the Wow6432Node registry entry indicates that you are running on 64-bit Windows version. When reading or writing from the HKLM\SOFTWARE\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path, the Windows Installer redirect to the HKLM\SOFTWARE\WOW6432Node\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path.
In order to avoid this, you can enable the Use 64-bit locations when evaluating conditions on a 64-bit machine option from the Prerequisite Install Conditions Tab article.
Please let me know if you have other questions.
Codename K
In some computers it installs the "AccessDatabaseEngine_X64.exe" registry entry to "HKLM\SOFTWARE\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path" and in some other computers is goes to "HKLM\SOFTWARE\WOW6432Node\Microsoft\Office\14.0\Access Connectivity Engine\InstallRoot\Path". When we enable "Use 64-bit locations when evaluating conditions on a 64-bit machine" it only checks 64bit location. In this case how to check for it please?
K
In order to achieve that, you can add another install condition that contains the "Wow6432Node" key in its path, so the installer will also check that registry path during the install conditions evaluation (see the attached image).
install conditions.png (41.65 KiB) Viewed 5292 times
You're welcome. Glad to help.
