alexander.lopes
Parse error in file: "" at line: [1] column [0] (code: syntax error).
Hi all,
I'm trying to create a Visual Studio Application, but when I import a Visual Studio 2015 Solution I'm getting the following error message:
Same error occurs when I try to import a WiX Setup Project.
Can you help me with this problem?
Alexander.
Re: Parse error in file: "" at line: [1] column [0] (code: syntax error).
Hello Alexander and welcome to our forums,
Could your please send us the related SLN and Project files (without source code files) to support at advancedinstaller dot com so we can test and investigate this on our side?
Hello Alexander,
Thank you for your sent files. I was able to replicate the import error with your sent files. This seems to be an Advanced Installer issue. We will try to add a fix in the future and we will let you know.
In the meantime, as a workaround you can try to manually create an Advanced Installer setup project from scratch. Since you are new, I highly recommend you read our tutorials for a better understanding of how to use Advanced Installer to efficiently deploy your products. This will also help you better understand support team's suggestions now and in the future. The Simple and Professional tutorials are especially important.
Also, as another solution you can install and use our Visual Studio extension and add into your VS solutions an Advanced Installer Setup project.
Hello Alexander,
A fix for this error was added and will be available in our next version of Advanced Installer (14.2). We will notify you when the fix will be out.
Until then if you need a RC version just send us a quick email to support at advancedinstaller dot com.
This was fixed in version 14.2 of Advanced Installer released on July 26th, 2017.
