There is some different between the package you mentioned form that I want to realize. The following is some screenshot about what I have done
(1)there are several options for user to choose the product to install
- 4.png (36.56 KiB) Viewed 3750 times
(2)if the first options was chosen, then the following dialog would be show
[img]2.png[/img]
(3)as (2), if third option was chosen, dialog would show as following
- 1.png (30.22 KiB) Viewed 3750 times
(4)when I run the package after the option 3 was installed, it show the maintain dialog. And if I choose the modify, It would show the following dialog
- x3.png (32.98 KiB) Viewed 3750 times
the quick selection tree in the modify dialog is the same as the tree of the option I choose when installing the package.but not organized by the options.
when making the package I have several problem
(1)In the first step above before, how can I extend the setup type dialog so that the package can deal with more options.
(2)In the second or third step above, how can I hide the feature not being selected so that the user can not see them. I was using the vbscript to decide features to be installed when different options was selected.Could this be achieved by vbscript or should be in other way
(3)When running the package again after installing one option, could the maintain dialog :delete,modify,repair show decided by whether the option chosen by the user is installed or not.
(4)and If the (3) can be achieve, can different option choose to install to different path, because we can see from the [img]x1.png[/img] or[img]x3.png[/img],there is no place to choose the path to install the option.
(5)and if different option or product in the package can be install to different path, could it be delete when uninstalling the package
It is a little bit more, thank very much for deal the problem.
