leonel
problem importing VS installer proj
I am trying to import an existing vdproj file. As soon as the process start I get a "application ran into a problem" message.
I wonder how could I get a more detailed information of what the problem is.
Attached is vdproj file.
thanks
SNSInstaller.vdproj.txt
(129.75 KiB) Downloaded 254 times
Screen Shot 2017-08-15 at 16.39.05.png (23.3 KiB) Viewed 2637 times
Re: problem importing VS installer proj
Indeed we can replicate the error. This seems to be an Advanced Installer issue. We will further investigate this and try to add a fix in a future version of our application. Thank you for bringing it to our attention.
In the meantime you could create from scratch your setup project by using one of our an "New -> Installer -> Generic Templates" project types. Since you are new, I highly recommend you read our tutorials for a better understanding of how to use Advanced Installer to efficiently deploy your products. This will also help you better understand support team's suggestions now and in the future. The Simple and Professional tutorials are especially important
This was fixed in version 14.3 of Advanced Installer released on September 18th, 2017.
