valiot
Allow Scheduled Tasks to run from a group not just a user
In Windows, you can create a scheduled task and assign it so it is run by a group (such as Administrators). In AI you can only choose a user. So the task will run if any user of that group is logged-in.
Re: Allow Scheduled Tasks to run from a group not just a user
This may happen if you are using the "Installed user" option. When our "Select an account" dialog picker is displayed the user group entries from "User and Groups" page are not displayed. Only the user account entries are displayed. This is an Advanced Installer limitation, thank you for bringing it to our attention. We will fix it in a future version of Advanced Installer.
However, please note that we do support for scheduled tasks to configure them to run under user groups. You should just use the "Property based user" and manually typing the user group name.
Let us know if this helped.
Return to “Feature Requests”
