cainrandom
Conflicting keyboard shortcuts in German EULA dialog
I know this is a bit particular, but a customer of ours raised this issue-- the "Alt + Z" keyobard shortcut on the EULA dialog is used twice, once for "Back" (&Zurück) and once for "I agree" (Ich stimme der Lizenzvereinbarung &zu).
Because of this, the keyboard short doesn't work.
Thanks!
Re: Conflicting keyboard shortcuts in German EULA dialog
I have tested the scenario and this is indeed the case. It seems that the accelerator keys for the "Back" button and "I agree' are the same, the "z" key set using the "&". We would like to thank you for reporting this issue. It has been brought to the attention of our development team and it will be solved in a future version of Advanced Installer.
As a workaround, you can go to the Translation page --> Default Strings and look for the "RadioButton.Text.IAgree#1" Localization ID.
Once you have found it, on the German list, edit the line so the accelerator key is not on the "z"
Example :"Ich stimme der Lizenzvereinbarung &zu" --> "Ich stimme der &Lizenzvereinbarung zu"
Or to whatever letter best suits your needs.
cainrandom
Thanks, Dan! You guys rock.
You're welcome and thank you for your kind worlds!
Please let me know if there is anything else I can help you with.
This was fixed in version 14.8 of Advanced Installer released on April 16th, 2018.
