ianpablo
unable to uninstall
When I want to uninstall a program (Ibackup extractor) an error appears that do not lend me uninstall it.
this is the problem:
Sin título.png (67.59 KiB) Viewed 2475 times
I need a solution please
Re: unable to uninstall
This error may occur if you are using a multilingual package with a display language selection dialog (for multi-language packages) in the Languages Tab. This is a known issue that occurs when your different language installations have different Product Codes.
In order to overcome this, you should use the same Product Code for all of your installation languages. Just, go to "Product Details page -> Product IDs tab and set the same Product Code GUID for all of your installation languages.
