InstallerBldr
100% CPU uninstall
Advanced Installer Enterprise v14.5.2 b83143
On uninstall on 2008R2 system, two bat files are left consuming 100% CPU. Seems to be happening while the uninstaller UI is displaying the text "Removing backup files". I have repeated this reliably several times on uninstallation.
Examples are:
File 1 'EXE5624.tmp.bat'
Contents:
@echo off
ATTRIB -r "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1"
:try
rd "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1"
if exist "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1" goto try
ATTRIB -r "C:\Users\MYUSER~1\AppData\Local\Temp\EXE5624.tmp.bat"
del "C:\Users\MYUSER~1\AppData\Local\Temp\EXE5624.tmp.bat" | cls
File 2 'EXE5587.tmp.bat'
Contents:
@echo off
ATTRIB -r "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1\MYPROD~1.EXE"
:try
del "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1\MYPROD~1.EXE"
if exist "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1\MYPROD~1.EXE" goto try
ATTRIB -r "C:\Users\MYUSER~1\AppData\Local\Temp\EXE5587.tmp.bat"
del "C:\Users\MYUSER~1\AppData\Local\Temp\EXE5587.tmp.bat" | cls
When the 2 cmd.exe processes fronting these bat files are killed via the Windows Task Manager, the installer will not proceed further with the 'Next' button.
Please advise, thanks.
Re: 100% CPU uninstall
Can you please send us by email to support at advancedinstaller dot com the following resources:
1. the AIP (project file) so we can test and investigate its settings
2. a verbose log of the uninstall
3. if possible, a download link for your built setup package so we can download and test it on our side too
We will need to further investigate this on our side.
InstallerBldr
I'm afraid I cannot share the installer executable. It contains a proprietary product I am bound not to release.
Instead I have a feature change request for those generated bat files that AI produces.
The problem with the way they behave now is that while they wait, they hammer the user's system at 100% CPU until the resource they are waiting for frees up. Even when that step completes successfully, if you watch the CPU usage it spikes to 100% from the start of the "Removing backup files" stage until the user clicks 'Finish'. To be clear, 100% CPU the whole time so if the user walks away without clicking 'Finish', or if the user kills the installation process at this time, the machine stays at max CPU. This needs to be industrialized a bit.
201803021517 - CPU maxxed during AI busy wait.png (282.38 KiB) Viewed 9726 times
201803021526 - CPU stops maxxing out on Finish button click.png (103.87 KiB) Viewed 9725 times
Here is a solution for AI to modernize that functionality for everyone. The following code is designed such that it is quick if the resource is available, but gracefully extends its time between tries each time the resource comes back unavailable, until it maxes out at a 4 second pulse.
This will solve that busy wait CPU spike for all AI's users with busy file systems or slower disks (like on a busy VM), while not delaying for users with responsive systems.
Can you please implement this ASAP?
Thank you.
File 2 'EXE5587.tmp.bat' rewritten (refers to the original file with the same name in the root post)
Contents:
@if (@CodeSection == @Batch) @then
@echo off
setlocal
set /a nice = 1
:try
if exist "C:\PROGRA~3\Caphyon\ADVANC~1\{1097A~1\MYPROD~1.EXE" (
set /a msDelay = %nice%
set /a "msDelay = 1 << nice"
call :pause %msDelay%
if %nice% lss 12 (set /a nice += 1)
goto :try
) else (
goto :EOF
:pause <ms>
cscript /nologo /e:JScript "%~f0" "%~1"
goto :EOF
@end // end batch / begin JScript hybrid code
WSH.Sleep(WSH.Arguments(0));
Thank you for your follow up on this and for your improvement suggestion. I've forwarded this to our development team and hopefully they will react positively to your suggestion.
As soon as such improvement will be adopted we will update this thread.
InstallerBldr
Thank you for your reply.
I want to be clear that we consider this a bug that needs to be fixed ASAP. We are installing our products on high traffic servers and cannot have the server unresponsive due to a period of 100% CPU usage by an installer utility waiting for a resource.
Can you please prioritize this fix? This, along with the config file problems viewtopic.php?f=2&t=34342&p=97733#p97733, is a blocking issue for us. We cannot release until this is fixed.
Yes, I added a high priority for your request and hopefully this will be available soon. However, I cannot give you any ETA for now. As soon as an improvement will be out we will update this thread.
You can see my reply on the "Duplicate comments in web.config file." forum's thread.
InstallerBldr
Thanks Daniel
You are always welcome.
This was fixed in version 14.9 of Advanced Installer released on May 24th, 2018.
