UHand
User specific customized Licence
I have changed the TrialTestVBExample Sample from "Serial Number" to a "User specific customized Licence"
see Picture "01 Lic - Template.png"
After Installing on Client side in the Registerdialog did not change ?!?!
see picture "02 Register Client.png"
When I generate the Licence "03 Generate Lic.png" all field have to be empty ....
Where is the Configuration / Api .... so the Custumer can add the Information, I ask in the Licence Template ....
Hope you understand my Issues
Best Regards
Uwe Handzik
01 Lic - Template.png (43.45 KiB) Viewed 4492 times
02 Register Client.png (42.78 KiB) Viewed 4492 times
03 Generate Lic.png (51.3 KiB) Viewed 4492 times
Re: User specific customized Licence
Hello Uwe and welcome to our forums,
If you want to manually generate the license then the user should send you (e.g. by email) the request code (actually this is the COMP_ID license element) and you should fill the COMP_ID license element with the customer sent request code and all the license elements with the license info handled and managed by you.
If you want to automate this license request procedure, then you should implement the steps exposed in our "How to configure a PHP or ASP.NET license server for my application?" article.
Hope this helped.
UHand
Hi Daniel
Sorry, did not help
I'm stuck with the COMP_ID (or Edition% TYPE%), how is this element filled out at the end user?
Can the end user type in the registration form?
Can i modify your registration form?
Can I fill it out via the API?
... and then send the entire package to my license server for evaluation - your PHP / ASP example ...
Best regards
Uwe
Hello Uwe,
Only the "COMP_ID" element is generated on the client side. You can access this by using our trial DLL's GetPropertyValue function. You could use it to access the "CompId" trial property.
If you want to automate the license registration on client side then you should implement and configure a license web server as exposed in the article I previously pointed to.
Otherwise the user should manually send you (e.g. by email) his license ID and the COMP_ID request generated on our trial dialog and then you should open Advanced Installer and use the "Generate License Dialog" to generate the license content. Finally you should sent back to the customer the license content and he should paste it into our trial registration dialog.
UHand
Hi Daniel,
I've got it! I was on a completely wrong way ...
It would be nice if yours in your documentation may include a small flow chart in which to see the flow.
Many thanks for the support !
Best Reagards
Uwe
You are always welcome Uwe.
I have added your request on our work list and we will try to update our user guide with a work flow illustration for a trial use case. Thank you for your suggestion.
