sjeslis
COM Server Registration Failures On Windows 7
We are still on AI 14.4.2 and haven't modified our installers for a while. I have several Custom Actions to register COM servers:
All of a suddenly in the last month or so these COM server registrations are failing on some Windows 7 machines and a Windows 10 machine, e.g.:
MSI (s) (40:FC) [11:47:54:834]: Executing op: CustomActionSchedule(Action=Register_CIFSBClient.exe.1774B61E_82C4_4E8C_8FBA_A705BBC46365,ActionType=3154,Source=C:\Program Files (x86)\Cicero Inc\CIC\Bin\CIFSBClient.exe,Target=/regserver,)
CustomAction Register_CIFSBClient.exe.1774B61E_82C4_4E8C_8FBA_A705BBC46365 returned actual error code -1073741819 but will be translated to success due to continue marking
P.S. After the install completes (as I don't abort when these CAs fail) I can run:
"C:\Program Files (x86)\Cicero Inc\CIC\Bin\CIFSBClient.exe" /regserver
from an Admin command prompt with no issue.
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
sjeslis
Re: COM Server Registration Failures On Windows 7
No further info then what's above at the moment.
Scott Jeslis
Cicero, Inc.
sjeslis
The DLL these depend on appears to be registered after the product is installed. That's registered via selfreg.
Almost seems like the deferred CAs aren't picking up the registration.
Scott Jeslis
Cicero, Inc.
sjeslis
This started happening to us on this merge module with limited changes when we upgraded our AIP from 13.5 to 14.4.2.
Scott Jeslis
Cicero, Inc.
Hello Scott,
I am not so sure why this happens. Please give us some time to test and investigate this scenario and I will get back to you as soon as I have a conclusion.
Thank you for your patience.
sjeslis
As an aside, the COM DLL and EXEs being register all reside within a Merge Module.
Scott Jeslis
Cicero, Inc.
Hello Scott,
We have further tested and investigated this scenario by using AI 14.4.2 but we are unable to replicate any such registration error within a "Launch attached file" custom action.
Can you please send us the .AIPs (project files) of your setup and merge module projects and a verbose log of the failing installation to support at advancedinstaller dot com so we can investigate them?
sjeslis
Thanks Daniel. We are looking into some things on our end.
Scott Jeslis
Cicero, Inc.
You are welcome Scott.
sjeslis
I am trying AI 15.5.1 :
Bug fixes
Solved issues with the "LaunchFile" custom action when using the options "Hide program's window," "Run under the LocalSystem account with full privileges" or "Wait for custom action to finish before proceeding."
to see if this makes the issue go away. We are using Launch File custom action and what we "think" we are seeing is that they are not running as Administrator.
Scott Jeslis
Cicero, Inc.
Hello Scott,
Indeed in our recent version of Advanced Installer we ran a redesign of our "Launch file" custom action and this generated two Launch file custom action issues which we fixed since AI 15.5 version.
Also, currently if you are using our support to launch your application at the end of the installation, more exactly the "Finish Actions" tab of the [Finish] button from "ExitDialog" on "Dialogs" page, then please keep in mind that our implementation has changed. Now the application is launched without elevation (admin rights) even the whole installation process runs elevated. We changed the implementation this way after getting quite a few requests for this behavior from several of our customers.
In the future we plan to add an option in the "Finish Actions" tab to configure the app being launched at the end of the installation to run as admin or not. For now, the only workaround will be not to use our "Finish Actions" tab and instead call a "LaunchFile" (with the "Run as administrator" flag set in "Custom Actions" page) custom action from an "Execute action" published event added on [Finish] button from "ExitDialog".
EDIT: Starting with our 15.9 version of Advanced Installer, on the ExitDlg there is the option to launch the application with admin privileges, regardless the package has the run as admin flag from the Install Parameters or not.
Hope this helped.
sjeslis
Yes my server install uses the Finish Actions tab (doesn't explain why on my 2016 Windows Server VM it appears to work, but not on the 2012 & 2016 Windows Server machines in QA).
This doesn't answer why I'm having a LaunchFile issue with COM Out-Of-Process Registration (e.g. dscserver.exe /regserver) on Windows 7 :|
Scott Jeslis
Cicero, Inc.
sjeslis
This Windows 7 related issue was detected on 14.4.2 I believe.
Scott Jeslis
Cicero, Inc.
Hello Scott,
I cannot say why the COM registration fails. We would have to further investigate this. For the beginning can you please send us the .AIPs (project files) of your setup and merge module projects and a verbose log of the failing installation to support at advancedinstaller dot com so we can investigate them?
Or any small sample which could help us replicate the behavior.
sjeslis
Strangely enough this turned out to be a TFS merge issue with one of our code files.
Thanks!
Scott Jeslis
Cicero, Inc.
