aho
Check if Input in Dialog is valid
I'm currently building an installer, where the customer can choose an instance name for SQL Server and a password for the sa user.
My questions is, how can I verify that the customer's input (in the dialog) is valid?
two examples:
    1. Check if the entered SQL instance name is allready used. I know where to look up in registry, but how can I read a registry value in dialog? Or is there a bettwer way than searching in registry?
    • Check if Windows Group Policy is configured that 'passwords must meet the complexity requirements'. If yes, check if the entered password is valid. Is something like that possible?
2018-12-27 16_12_37 Password Complexity Check .png (108.28 KiB) Viewed 3504 times
Re: Check if Input in Dialog is valid
This can be done through a registry search. For more information about this, please see the following articles:
- "Search Page"
- "Extended Search Properties"
From what I know, the "Password must meet the complexity requirements" does not have a registry key assigned to it, so checking if that option is enabled can turn out to be pretty troublesome and unfortunately I am not aware of any way in which you can check that. In what regards the password check, I think that it can be done through a PowerShell script. From what I know, the things that you should look after are:
1- the password must contain at least one lower case character (e.g. a-z)
2- the password must contain at least one upper case character (e.g. A-Z)
3- the password must contain at least one numerical character (e.g. 0-9)
4- the password must contain at least one special character (e.g. !@#$%)
5- the password must be at least 8 characters long
Every dialog field has a property assigned to it that stores its value. This applies to the SQL password field from the SQL Dialog as well. The property that stores the password is:
PASSWORD_PROP
In order to retrieve a property value in a custom action (e.g. PowerShell script), you can use the following line:
$var = AI_GetMsiProperty PASSWORD_PROP
This way, the $var variable will have the value of the password inserted by the user. For more information about this, you can have a look on the following articles:
- "Windows Installer Custom Actions"
- "Custom Actions Page"
- "Run Inline PowerShell Script"
- "How to set an installer property using custom actions"
aho
Thanks for your reply!
It worked that way.
You are always welcome.
I am glad I could help.
