Minnu123
Uninstalling pre requisite softwares during uninstall of application
Hi
Our installer is installing five third party software's as pre requisite, while installing our application. During uninstall of our application from control panel, I need to silently remove all these third party softwares. Can anyone please advice a method to remove the third party softwares which are installed by our installer.
Thanks in Advance
Re: Uninstalling pre requisite softwares during uninstall of application
In order to achieve that, you can make use of the "Uninstall using this command line:" option from "Prerequisites" page --> your prerequisite --> "Setup Files" tab --> "Maintenance Command Lines" section:
"Prerequisites Setup Files Tab"
