Thank you for your followup on this. Things are a bit more clear now.
In what regards this:
1) a user logs in with their own account, runs the installer, preferably without requiring admin rights, and ends up with a per-user install
This can be achieved by using the
"Per-user only" installation type from the
"Install Parameters" page.
However, this contradicts the following:
There are multiple files that are installed in C:\Program Files (x86)\xyz.
A program can not write to the
"Program Files" folder without the user providing administrator rights.
This can pretty much be solved by using the
"Per-user only (admin rights required)" installation type.
However, the above solution contradicts the first point (
"preferably without requiring admin rights"), where you want the user to not be forced provide elevated privileges.
This:
There are multiple files that get installed in the user's personal folder.
and this:
There are reg entries that must be made per user.
can both be achieved by using the
"Per-user only" installation type.
2) an IT admin logs in to the computer's admin account, runs the installer and does a per-user install for a specific, named user who has an account on that machine; the end result should be the same as #1: a per-user install that is NOT for the admin account but for the named user's account.
To be fully honest with you, I am not sure this is even possible. I have never heard of such case, where a user installs a setup for another user.
However, you can have a look on our
"How to install a user specific file" article which I think you may find useful.
Although I am not quite sure if that is worth, you can try it and hopefully it may be of help for you.
As a conclusion, I think that the best option for your scenario would be to use the
"Per-machine if user is administrator, per-user otherwise" installation type. This option is intended to work with the
"InstallTypeDlg" dialog which can be added to your project by using the
"Dialogs" page.
