sreedevibalachandran
Do not uninstall driver while upgrading
I have created a setup for my project. But we may need to create patches for the same in future. We have our own method for auto update. I cannot use AI's auto update feature now. So I was trying to use Upgrades option. But while running an upgraded exe, drivers are getting uninstalled. Is there any way to not to uninstall drivers and prerequisites while we upgrade our installer project? Please help.
Re: Do not uninstall driver while upgrading
An upgrade basically means the removal of the older product and the installation of the newer product. With that being said, it is normal for your files to be deleted and then replaced.
In order to achieve this, please have a look on our "How do I prevent a file or registry entry from being uninstalled or repaired?" article which I think you may find useful.
