berqo127
License error
Using Advanced installer build extension for Azure pipeline yield error -
"This type of project requires an enterprise license. You may use it for evaluation purposes ONLY. Advanced Installer has a trial period of 30 days. After the trial expires, licensed projects can still be created, but they cannot be built to generate an installation package. Days left in your trial period: 0."
even though there is a license and I don't get this error using the advanced installer editor.
Shlomi
Re: License error
Hello Shlomi,
This may happen if you did not specify your Advanced Installer license key to be used in the "License Key" field of your Advanced Installer build task of your Azure DevOps pipeline.
Could you please double check this?
ionut.boronea
Re: License error
I'm getting the same error but with the license key specified.
##[error]Failed to execute Advanced Installer task. Error: SetOutputLocation -path "D:\a\1\a\Setup File" -buildname "DefaultBuild"
The task:
- task: AdvancedInstaller@2
inputs:
advinstLicense: '$(AILicense)'
aipPath: 'Installer.aip'
aipBuild: 'DefaultBuild'
aipOutputFolder: '$(Build.ArtifactStagingDirectory)\Setup File'
Ionut
Re: License error
Hello Ionut,
Could you please make sure that your project is not of "Enterprise" type?
You can do so by opening your project --> "Home" tab --> "Options":
ionut.boronea
Re: License error
Hello Catalin,
The project is of type "Enterprise" but the license is also an Enterprise license.
You can't use an enterprise type project with Azure DevOps?
Thank you.
ionut.boronea
Re: License error
So can I get an answer?
Thanks.
Re: License error
Hello Ionut,
Please accept my apologies for the delayed reply.
Azure DevOps should work just fine with the Enterprise project. Could you please make sure that there is no typo in the License Key you have provided?
Also, if you used the copy-paste mechanism, could you please make sure that there is no empty character at either the beginning or the end of the string?
ionut.boronea
Re: License error
Hello Catalin,
Thank you for your reply.
There is no issue with the license. The only thing that might influence this is the maintenance which is expired.
Is this possible?
Also, is it possible that there might be another error but this one is displayed?
Thank you.
Re: License error
Hello Ionut,
This indeed could be a problem if you did not mention the Advanced Installer version covered by your Maintenance Plan:
https://www.advancedinstaller.com/user- ... section643
ionut.boronea
Re: License error
Hello Catalin,
Thank you for your help.
This was indeed the issue.
Have a great day!
Ionut
Re: License error
You are always welcome, Ionut!
I am glad everything works as expected now.
You have a great day, too!
GSI_Peter
Re: License error
I am experiencing this same issue. It will succeed occasionally, but 9 times out of 10 it fails with this error:
But, I do in fact have an active Enterprise license. I am attempting to use the Use Advanced Installer Tool to get hopefully get around this, but I have to go through my IT department for approval for new extensions in Azure DevOps so that is taking a while.
We do not experience this issue when build Advanced Installer projects on our on-premise server, only DevOps in the cloud.
Any advice?
Peter
Re: License error
Hello Peter and welcome to our forums,
This is indeed quite strange.
Could you please make sure you have passed the license in your DevOps pipeline?
GSI_Peter
Re: License error
I double checked that the License Key field is populated. I was storing it in a pipeline variable, but when we started having problems I also tried entering the license code string directly in the License Key field. Neither are working reliably at this time.
Peter
Re: License error
Hello Peter,
Please note I have sent you an email regarding this.
Let's continue the thread there for now.
