Abhinay
How to get the value of the checkbox
How to get the value of the chekbox.
Param()
# Your code goes here.
Add-Type -AssemblyName PresentationFramework
cd "C:\Program Files\Weir Minerals\RSP Firmware\RSP Firmware\"
  #Choose the Device to update Firmware
$SP1 = AI_GetMsiProperty CHECKBOX_SP1
$DAQ1 = AI_GetMsiProperty CHECKBOX_DAQ1
[System.Windows.MessageBox]::Show("$SP1")    ---- if i run this it gives me the output on the message box as checkbox but i need the value of it like true or
        false
if ($SP1 -eq "True")
   $a = .\SinetProg.exe /i /a:192.168.29.20
  [System.Windows.MessageBox]::Show("SP1 $a")
elseif ($DAQ1 -eq "True")
  $b = .\SinetProg.exe /i /a:192.168.29.21
  [System.Windows.MessageBox]::Show("DAQ1 $b")
Re: How to get the value of the checkbox
Please note that when a checkbox is ticked its property is set to the string you set in the "Value" field from "Properties" right pane.
When it is not checked, then its property value will be set to empty string ("").
So you should check within your script if statement that the property value is equal or not with the string set in the "Value" field from "Properties" right pane.
Hope this helped.
Abhinay
Thank you it helped.. But i had different requirement and was able to resolve it myself.
You are always welcome.
I am glad you got this resolved.
