aho
Change File Attributes of the Setup Wizard
I want to change a file property of my setup.exe.
An installer property shall be changed with the SetProperty command ( https://www.advancedinstaller.com/user- ... perty.html ).
The value of the installer property shall be written to the ProductVersion oder FileVersion Property of the installer.
Note:
I already use the "Set version from file" function. So ProductVersion and FileVersion are set to the version of the configured file. Later I want to overwrite (f.e. ProductVersion) with the value of the installer property.
How can this be done?
Andreas
Re: Change File Attributes of the Setup Wizard
Hello Andreas,
If I understand this correctly, you want to overwrite the Product Version of your setup (please correct me if I'm wrong). To do so, you can take advantage of the "Set Version" command. Please have a look on our "Set Version Command" article for more information about this.
aho
thanks for your reply. I think my explanation was not good.
I want to put information from our build server into the setup.exe file as a file attribute.
I do not want to change the ProductVersion of the MSI package.
This information from the build server can also contain characters - not only numbers.
Have a look at this screenshot:
2019-09-11 17_23_03-exe properties file description - Google-Suche.png (16.61 KiB) Viewed 9758 times
The best solution would be if I can change the file description of my setup.exe.
Is this possible?
Andreas
aho
Any ideas?
Andreas
Hello Andreas,
First of all, please accept my apologies for the delayed reply (I had 2 days off last week and we also do not work over the weekend).
In order to change the "File Description" attribute of your setup.exe, you can proceed as it follows:
1. go to "Builds" page
2. under the "Output" section, click on the "Customize EXE metadata"
3. there, you should be able to customize your setup attributes
