micke
Add directory with Jar files to Classpath
I have a problem that the file names of the jar-files changes between builds. For example:
lib/module1-1.0.jar
lib/module2-2.3.jar
lib/module2-2.4.jar
I use the feature of adding a directory under "files and folders" to add all jar-files. Then i configure the java runner with the jar-files and build my msi installation. In the next release version numbers have changed:
lib/module1-1.1.jar
lib/module2-2.4.jar
lib/module2-2.5.jar
As it is today i have to modify my advanced installer project to get the new files and also modify my java product to use the new files in classpath. I would like advanced installer to pick upp the new files automatically without manual work by me. Why not add a feature to add files in a directory whichis scanned every time the project is built. All the files in there should also be included in the java product classpath.
Regards
Mikael
Cosmin
We will consider including this feature in a future version of Advanced Installer.
Thank you for your suggestion.
Cosmin
Return to “Feature Requests”
