enigma
ShortCut name cannot evaluate the [ProductVersion] constant
I need to define a shortcut to an exe in my desktop, and that shortcut needs to have a name of the format [ProductName][ProductVersion] (e.g., "My App 1.0.2.0"). I tried to set the "Name" in the new shortcut dialog box as "My App [ProductVersion]". However, the shortcut name I got was "My App [ProductVersion]", but not "My App 1.0.2.0". Please advice here.
Cosmin
Currently this cannot be done in Advanced Installer. However, this feature is on our TODO list and it will be available in a future version of Advanced Installer.
Cosmin
fd1
You can create a custom action of type EXE with Working Dir in the Commit stage for example and use a command line to rename your shortcut:
Working Dir=SystemFolder
Full Path=cmd.exe /Q /C "ren "C:\Documents and Settings\All Users\Start Menu\Programs\My App" "[ProductName]""[ProductVersion]""
Daniela Petrescu
This feature has been added to Advanced Installer 6.1.
You can now name a shortcut using properties e.g.
"[|ProductName] [|ProductVersion]" => "My App 1.0.2"
Note that the shortcut name is of pseudo formatted type, so you must use "[|...]" to refer a property.
You can read more about latest features added to Advanced Installer 6.1 on http://www.advancedinstaller.com/release-6.1.html.
Daniela
_________________
Daniela Petrescu
Advanced Installer Team
