adlag
problems with windows font size
I notice the following font-size problems:
1. Desktop font-size settings to normal:
Button captions are only partly readable if caption
get clipped due to word length, for instance:
"utilisation du disque". They "fall off" the button.
2. It gets much worse if font-settings of the windows
desktop are set to large (older people often do that, and
older people can be quite influential in organizations.)
Many text and text-boxes and figures spill over in Adv Inst.
Text runs outside borders etc. In Wise and Installshield the dialog
boxes are rescaled such that this does not occur.
Greetings
Ad
Cosmin
Please note that Advanced Installer allows you to set the "Stretch with fonts" option in the "Global Properties" page in order to avoid this behavior.
You can read more about this feature here:
http://www.advancedinstaller.com/user-g ... theme.html
Cosmin
