AlexanderAnishchik
MySQL port discovery
Hi, I need to install MariaDB (the same as MySQL) with my program. I've added MySQL msi file as prerequisite for application but now I need to figure out if MySQL already running on some of predefined ports (3306, 3307, 3308). How Can I achive that? Should I write custom action or use some of Enterprise AI features?
Re: MySQL port discovery
Hello Alexander,
You do not have to write your own custom action for this. You can use our predefined custom action "CheckFreeTCPPort".
Please have a look on our How to check if a TCP port is free by using a custom action article for more information about this.
Also, more information about the custom action itself can be found in our "Custom Actions list - Check TCP Port" article.
AlexanderAnishchik
Thanks. What if I want to check several tcp ports? And one more questions: Is it possible to run one inline powershell script created in AI from another one?
Hello Alexander,
There are two ways in which you can check more TCP ports:
1. You can add multiple "CheckFreeTCPPort" custom actions and, after each custom action is executed, have another "Set Property" custom action which will set the value of a property to the value of AI_PORT_TEST_RES property. Basically, you need to save the value of AI_PORT_TEST_RES property in another property due to the fact that each time the custom action is executed, that property will be overwritten.
2. You can follow the approach described in the "Check multiple ports" thread.
Unfortunately, this is not possible. This is only possible from a C++/VBS custom action (through the MsiDoAction and Session.DoAction methods).
AlexanderAnishchik
Thanks! I'm using your suggestion about several custom actions in a row but now I need to put them before installation of prerequisites. The time to execute takes around 2-3 sec. I can't bind it to Next button because I want to use Basic UI level for Pre-install. Where should I put these custom actions?
The basic Pre Install UI overlaps progress text. Why so?
Hello Alexander,
In order to achieve that, you can add your script as a custom action without sequence and then schedule it as an "Init Event" in the "PreparePrereqDlg" dialog ("Dialogs" page --> "Pre-instlall UI")
In what regards this, I am not quite sure why this happens. Can you reproduce it constantly?
