jstuardo
"Changed database context" error
I have this SQLServer Dialog:
When I press "Next" button, TestODBCConnection custom action is called, but the same dialog stays. I need to cilck "Next" button again in order to continue with the next dialog in the wizard.
Later, when installing, at Executing Install SQL script stage, a "Change Database Context" error is shown.
How can I solve it?
I am attaching the project file as well.
By the way, this started happening when I added TestODBCConnection functionality using instructions in this page: https://www.advancedinstaller.com/user- ... ction.html
Regards
Jaime
Control de Visitas 3.aip
(92.74 KiB) Downloaded 317 times
Re: "Changed database context" error
Hello Jaime,
I believe we discussed the first part of this thread here:
Bad behaviour when using Test ODBC Connection dialog
In what regards the second part of the thread, that is an SQL Driver predefined message that appears when the working database is changed.
Please have a look on the following thread which I think debates a similar scenario:
SQLExecDirect error message
