EugeneK
DevOps and Synced folders
We have problems with making "Advanced Installer Build" step working correctly in DevOps pipeline. Version is latest - 16.8.
In the AI project, we have the following structure:
Image 5.png (136.67 KiB) Viewed 5578 times
So, in the APPDIR, there are two synced folders: Configurator and Publish.
In the DevOps step we have this configuration:
Image 6.png (105.89 KiB) Viewed 5578 times
Additionally, before this step, we update APPDIR folder location in the project file using Update XML file attribute step:
Image 7.png (94.14 KiB) Viewed 5578 times
Where Value is actual path to a folder where source files for Configurator are stored.
However, when building an installer it looks like folder sync doesn't happen and AI says that files can't be found:
Resources referred by the project are missing:
Listing all files from Configurator folder
Do you notice what we're doing wrong?
Re: DevOps and Synced folders
Hi and welcome to our forums.
This error appear when files contained by the project (that were added manually, not through the synchronize option) are not present on the machine at the path stored in the project.
Are you sure that the listed files are present on the machine at the paths specified in the error log?
EugeneK
Eusebiu wrote: ↑Thu Mar 05, 2020 4:08 pm Are you sure that the listed files are present on the machine at the paths specified in the error log?
That's the problem. Actually, no! On the machine where I create installer, relative paths to the installer project file are different. And for some reason folder sync doesn't work and AI continues to look for files in a relative folder.
I'll try to clarify.
Project file has this synced folder entry:
  <COMPONENT cid="caphyon.advinst.msicomp.SynchronizedFolderComponent">
    <ROW Directory_="Publish_Dir" SourcePath="..\BaccS_XAF.Web\bin\Release\Publish" Feature="MainFeature" ExcludePattern="*~|#*#|%*%|._|CVS|.cvsignore|SCCS|vssver.scc|mssccprj.scc|vssver2.scc|.svn|.DS_Store" ExcludeFlags="6"/>
    <ROW Directory_="Release_Dir" SourcePath="..\..\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release" Feature="MainFeature" ExcludePattern="*~|#*#|%*%|._|CVS|.cvsignore|SCCS|vssver.scc|mssccprj.scc|vssver2.scc|.svn|.DS_Store" ExcludeFlags="6"/>
  </COMPONENT>
Publish_Dir is one folder higher than project file. Release_Dir is two folders higher.
In the pipeline, I change source path of Release_Dir to concrete folder, in my case it is:
C:\builds\219\s\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\
However, when AI gives an error, it says this:
Registering Advanced Installer.
C:\builds\_tool\advinst\16.8.0\x86\bin\x86\AdvancedInstaller.com /RegisterCI ***
Prepending PATH environment variable with directory: C:\builds\_tool\advinst\16.8.0\x86\bin\x86
C:\builds\_tool\advinst\16.8.0\x86\bin\x86\AdvancedInstaller.com /execute "C:\builds\219\s\Advanced Installer\TBM Online.aip" C:\builds\_temp\84311.aic
SetPackageName "sdl_business_manager_online_5.2.5.0.exe" -buildname ""
SetOutputLocation -path "C:\builds\219\s\Advanced Installer\Setup Files\TBM Online 5.2.5.0\" -buildname ""
Build
Checking builds status
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\EMSWrapper.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\Sdl.Common.Licensing.Manager.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\Sdl.Common.Licensing.Provider.Core.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\Sdl.Common.Licensing.Provider.SafeNetRMS.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\Sdl.Core.PluginFramework.PackageSupport.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\Sdl.Core.PluginFramework.dll
C:\builds\219\BaccS_Team_Licensor\BaccS_Team_Licensor\bin\Release\SentinelLicensing.dll
etc...
So, instead of searching in provided folder, AI continues to search files in a relative folder initially specified in the project file. I made a conclusion that sync doesn't happen at all and AI continues to rely in files already listed (synced) in a project.
Does it make any sense?
This may happen if the old files remain in the "Release_Dir" folder even if it was synchronized to the new path. To avoid this, you can reset the synchronization of that folder, then synchronize it again, but choose to delete the existing files (-existingfiles delete).
EugeneK
Thank you, Eusebiu!
However, I have a new question then.. If to follow this, will this option be preserved?
Image 2.png (55.01 KiB) Viewed 5532 times
As well as will assemblies added to GAC on the Assemblies page (linked with files from a synced folder) be kept?
You're welcome.
I'm afraid that the settings you mentioned (install to parent and assemblies) will be lost when the synchronization of a folder is reset. To avoid this, you can open the project and remove the junk files manually.
