david.sanda
Error 2607 - Media table not found or empty (required for installation of files) for simple installer
Hi Guys, i have a trivial installer we use to wrap appx and dependencies to single file and install it using custom actions.
msiexec /a <personal installer.msi> fails with the error below. /i does not.
ends with Error 2607 - Media table not found or empty (required for installation of files)
Attached is our AIP file exactly as it is except for masking identity of the company:) Version 16.8. Professional edition. Please advise.
PersonalX.aip
(30.38 KiB) Downloaded 297 times
Re: Error 2607 - Media table not found or empty (required for installation of files) for simple installer
This happens because you are using the /a (administrative install) command. This command is used to extract the regular files packaged into your setup package. Since your setup project includes only temporary files there is no regular file to be extracted and thus the related error message.
To launch your setup installation and deploy it please use the /i (install) command. Have a look over our msiexec commands article.
Hope this helped.
