toonetown
Need to delay driver service starting
I have an application which installs a driver and some files, and it also runs a command - but it needs to run the command prior to services (including the driver) being started.
I have the following custom actions (in this order)
- InstallFiles (standard action)
- Custom Action (executes a file that is installed)
- PatchFiles (standard action)
The driver ini is installed during the InstallFiles section as well. However, when I look at the installation log, I see the following:
MSI (s) (C4:34) [18:35:31:737]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI8019.tmp, Entrypoint: InstallDriverPackages
DIFXAPP: ENTER: InstallDriverPackages()
DIFXAPP: INFO: 'CustomActionData' property 'DIFxApp Version' is '2.1.1'.
    <...SNIP...>
DIFXAPP: INFO:   Service 'mydriver' was started
DIFXAPP: SUCCESS:Installation completed with code 0x0.
    <...SNIP...>
DIFXAPP: RETURN: InstallDriverPackages() 0 (0x0)
This happens BEFORE the code which runs my custom action:
MSI (s) (C4:CC) [18:35:32:393]: Executing op: CustomActionSchedule(Action=MyCustomAction,ActionType=3090,Source=C:\Path\To\My\Binary.exe,Target=-a 123 -b 456,)
However - I need to have "C:\Path\To\My\Binary.exe -a 123 -b 456" execute BEFORE the "mydriver" service is started. How can I defer the starting of the service? The StartServices standard action is even after the PatchFiles standard action.
Re: Need to delay driver service starting
In order to launch your executable before the driver is installed, you can add the .EXE file as a "Temporary File" and then schedule your custom action to execute before the "InstallFiles" standard action.
Unlike Advanced Installer's regular files or resources, "Temporary Files" are copied on the target machine at the beginning of the installation and are deleted at the end of it (you can also opt for not deleting them), ensuring you have access to them throughout the entire install process.
The driver install action is executed right after the "InstallFiles" standard action, so if you need your custom action to be executed in between those standrad actions you should proceed like this:
1. go to "Table Editor" page and select the "InstallExecuteSequence" table
2. edit the sequence of "InstallFiles" action to be 3999
3. edit the sequence of your custom action to be the next one after "InstallFiles", i.e. 4000; check the attached screenshot
4. save and rebuild your setup project
The above step 2 is required because at setup project build time Advanced Installer includes into your setup the "MsiProcessDrivers" standard action with the execution sequence set to 4001. By default this is first sequence right after "InstallFiles" action.
Hope this helped.
toonetown
Thank you both - Daniel's solution worked for us, and is closer to what we are wanting to achieve.
You are always welcome.
We are glad you got this working.
