toonetown
Building Mixed AMD64/ARM64 package
Wed Nov 18, 2020 5:30 pm
How would we go about building an AMD64/ARM64 mixed installer (similar to how you would build a 32/64-bit mixed installer)?
Re: Building Mixed AMD64/ARM64 package
Wed Nov 18, 2020 5:54 pm
I am afraid it is not possible to create a mixed AMD64/ARM64 installer.
However, if you need to create distinct install packages of your products, configured for different platforms or editions, you can use our support for Multiple Builds.
toonetown
Wed Nov 18, 2020 6:07 pm
Doing this will result in multiple MSI files being created - is that correct?
Is there a future feature planned to do mixed ARM/Intel installers in a single MSI?
Wed Nov 18, 2020 6:34 pm
You are indeed, correct.
Unfortunately, there is not. I will add this on our TODO list of improvements.
However, to be fully honest with you, I am not quite sure that is possible to achieve.
toonetown
Wed Nov 18, 2020 6:53 pm
OK - thank you for the quick response!
Wed Nov 18, 2020 7:01 pm
You are always welcome!
