jjardina
Air Theme shows strange behavior
AI version 17.7
Select Air Theme, any type Air, Breeze, White or Flat
Insert a 370x304 background image
If you choose enhanced user interface in Theme settings: backgrounds in dialogs are broken, buttons and text are missing, etc.
It doesn't matter what image scaling setting you choose, dialogs are messed up.
If you choose never on enhanced user interface, dialogs are correct however disk space requirements, space available and remaining free space are all zero kb on FolderDlg screen.
Is there a way to get the disk information without using enhanced interface setting?
Re: Air Theme shows strange behavior
I tested this, but I could not reproduce the problem. Can you please send me a sample buildable project that reproduces this, so I can investigate it?
You can achieve this as explained in the "How to add disk space indication?" thread.
jjardina
Eusebiu wrote: ↑Wed Dec 09, 2020 8:31 am
Thank you for this, I have followed the instructions and added the pre-installer property of PRIMARYFOLDER and I now get data in the disk resources.
Also, I will send my aip and background graphic to you via email for your review. I have also attached screenshots.
As for now this was enough information to get me working without Enhanced UI. You should really put those instructions in the AI F1 help menu.
jjardina
I got the disk data to show up by following those directions, however the backgrounds are still corrupted when using enhanced ui. I sent my aip file and background image to you via email to try on your end and see if you could replicate the issue or tell me why the dialog backgrounds are showing corrupted.
I did not receive your email with the AIP and background file. Can you please tell me when you sent them and what is the email subject?
