Prim
Modify from Windows Control Panel
When using the modify button from Windows Control Panel, the installer design/layout looks broken.
It looks like it was launched with half the Dialogs setup in the .aip
Any idea where it could be from ?
Or maybe a way to personalize the dialogs for Windows Installer ?
Re: Modify from Windows Control Panel
When the "Modify" option is used in the Control Panel, the setup is launched in "Maintenance" mode.
The dialogs in Maintenance mode are not the same as the dialogs in the first time install.
These dialogs can be modified using the "Dialog Editor" feature, available starting with our Enterprise suite.
To do so, simply go to "Dialogs" page and check the dialogs from under the "Maintenance" section.
