sumit1
Finding installed product path
I would like to get installed application full path with version.
It's possible to find product path with version at the time of product installation time.
Please suggest your solution.
Thank You
Re: Finding installed product path
Are you refering to an application created with Advanced Installer here?
If that is the case, as default, a setup created with Advanced Installer automatically adds two entries in the registries - Version and Path. You can check this by opening your Advanced Installer project --> "Registry" page.
Based on these, you can create a "Registry Search" in the "Search" page.
sumit1
Thanks Catalin
But in my AIP product name is empty. At the time of installation we entered the installation path manually. So is there any way to access/get specific product installed path with version.
Not quite sure why you guys have manually removed those entries from the "Registry" page, however, luckily, there is another way of finding out the path.
The path and some other entries are saved in the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{Product_Version}
