Hello, Catalin. Thank you for the reply. My issue is not with reading from the CustomActionData property in my custom action. That all works fine. It's with the value of a public property not being passed in to CustomActionData by Windows Installer.
My first custom action is a function exported from a DLL written in C++. It is executed via dialog event after collecting SQL database connectivity information. The custom action simply generates a DSN string taking into account any property value escaping that needs to occur. The resulting DSN is stored in the property "DB_LOAD_DSN". This custom action is working with no problems. You can see it here in the generated setup.log:
MSI (c) (EC:74) [06:32:20:436]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is 'DbExists'. Its new value: 'TARGET=DB_LOAD_DSN;PROPERTIES=DB_SERVER,DB_DATABASE;Provider=MSOLEDBSQL;DataTypeCompatibility=80;Server=DB_SERVER;Database=DB_DATABASE;Integrated Security=SSPI'.
Action ended 6:32:20: AI_DATA_SETTER_32. Return value 1.
MSI (c) (EC:74) [06:32:20:436]: Doing action: SqlServerConnectionDlg
Action start 6:32:20: SqlServerConnectionDlg.
Action ended 6:32:20: SqlServerConnectionDlg. Return value 1.
MSI (c) (EC:74) [06:32:20:436]: Doing action: SqlCreateLoadDsnTrusted
Action start 6:32:20: SqlCreateLoadDsnTrusted.
MSI (c) (EC:84) [06:32:20:436]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\2\MSIEF0A.tmp, Entrypoint: IS_MsiExpandDsn
MSI (c) (EC!54) [06:32:20:468]: PROPERTY CHANGE: Adding DB_LOAD_DSN property. Its value is 'Provider=MSOLEDBSQL;DataTypeCompatibility=80;Server=localhost\SQLEXPRESS;Database=Test;Integrated Security=SSPI'.
Action ended 6:32:20: SqlCreateLoadDsnTrusted. Return value 1.
You can see above that the property DB_LOAD_DSN is set to the value "Provider=MSOLEDBSQL;DataTypeCompatibility=80;Server=localhost\SQLEXPRESS;Database=Test;Integrated Security=SSPI"
My second custom action (LoadDatabase_Cost) is also exported from a DLL written in C++. It is executed via the "Call Function from Attached Native DLL". It loads a SQL database from data in a custom file form at we use here at the office. It needs to be passed a SQL connection DSN (the value of DB_LOAD_DSN) and the file from which to load the data. I have it configured as follows:
- action.jpg (89.91 KiB) Viewed 20396 times
As you can see from the above screenshot, the Action Data is [DB_LOAD_DSN];File=[AI_DBD_FILE]".
The custom action is scheduled as follows:
- scheduled.jpg (36.73 KiB) Viewed 20396 times
When the install runs, the LoadDatabase_Cost receives the following data. Notice the value of DB_LOAD_DSN is missing (it should be before the semicolon):
;File=C:\Users\ADMINI~1\AppData\Local\Temp\2\TestProduct\Data.dbd
I have confirmed this is an issue with how Windows Installer is passing the data to my custom action, not the custom action itself. From the log:
MSI (s) (A4:80) [06:32:36:146]: Doing action: AI_DATA_SETTER_7
Action start 6:32:36: AI_DATA_SETTER_7.
MSI (s) (A4:80) [06:32:36:146]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is 'C:\'. Its new value: ';File=C:\Users\ADMINI~1\AppData\Local\Temp\2\TestProduct\Data.dbd'.
Action ended 6:32:36: AI_DATA_SETTER_7. Return value 1.
Further, when Windows Installer spawns the new msiexec process, it does not pass the value of DB_LOAD_DSN. From the log:
MSI (s) (A4:80) [06:32:36:005]: ******* RunEngine:
******* Product: C:\Users\Administrator\AppData\Roaming\TestCompany\TestProduct\install\TestInstall.msi
******* Action: INSTALL
******* CommandLine: **********
...<snip>...
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding APPDIR property. Its value is 'C:\Program Files (x86)\CompanyName\TestProduct'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Modifying DB_HAS_LOGIN property. Its current value is '0'. Its new value: '1'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Modifying DB_BACKUP_FILE_ESCAPED property. Its current value is 'db.bak'. Its new value: ''''.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Modifying DB_SERVER property. Its current value is 'localhost'. Its new value: 'localhost\SQLEXPRESS'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH property. Its value is 'C:\Users\Administrator\Desktop\TestInstall.exe'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH_ORIGINAL property. Its value is 'C:\Users\Administrator\Desktop\TestInstall.exe'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_DBD_FILE property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\2\TestProduct\data.dbd'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_INSTALLSUPPORT_DLL property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\2\TestProduct\InstallSupport.dll'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Windows User'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Caphyon'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Administrator\AppData\Roaming\CompanyName\TestProduct\install\'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '5'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_MORE_CMD_LINE property. Its value is '1'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2492'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding CHAINERUIPROCESSID property. Its value is '748Chainer'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'C04995A3299245EBA2122CEA2FA525AD,A2119716F144C9480694BF36747BC88,CE6A2D55BB654A48ADDB534115E9C322,D5D54AFFAD641D2B30BF3F03FA9D51C,MainFeature'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding PASSWORD_MATCH property. Its value is '1'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_PREREQDIRS property. Its value is 'C:\Users\Administrator\AppData\Roaming\CompanyName'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_TEMP_FILE_ROLLBACK_INFO property. Its value is 'C:\USERS\ADMINI~1\APPDATA\LOCAL\TEMP\2\TESTPRODUCT\DATA.DBD|C:\USERS\ADMINI~1\APPDATA\LOCAL\TEMP\2\|C:\USERS\ADMINI~1\APPDATA\LOCAL\TEMP\2\TESTPRODUCT\INSTALLSUPPORT.DLL'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AITEMPFILESEXTRACTED property. Its value is 'YES'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding AI_FOUND_PREREQS property. Its value is '.NET Framework 4.7.2|Visual C++ Redistributable for Visual Studio 2015-2019 x86|Visual C++ Redistributable for Visual Studio 2015-2019 x64|SQL Server OLE DB Driver 18 x64|MSXML 6.0 Parser SP2 x86|MSXML 6.0 Parser SP2 x64'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding SETUPEXEDIR property. Its value is 'C:\Users\Administrator\Desktop\'.
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding EXE_CMD_LINE property. Its value is '/exenoupdates /forcecleanup /wintime 1611785946 /L*V "C:\Users\Administrator\Desktop\Setup.log" '.
MSI (s) (A4:80) [06:32:36:021]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (A4:80) [06:32:36:021]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'cb3c6557bf12bd42ab84e551830e8926'.
MSI (s) (A4:80) [06:32:36:021]: RESTART MANAGER: Session opened.
MSI (s) (A4:80) [06:32:36:021]: Engine has iefSecondSequence set to true.
I have also noticed that it does not pass a number of public properties that I have set and I cannot find any consistent reason for that.
For example, I have another property DB_RUNTIME_USERNAME that is defined in the property table and associated with a dialog control. This property is NOT passed to InstallExecuteSequence. DB_SERVER, which is configured exactly the same way so far as I can tell, is passed to InstallExecuteSequence.
A second example, DB_BACKUP_FILE_ESCAPED, is set during a custom action during the InstallUISequence, just like DB_LOAD_DSN. However, DB_BACKUP_FILE_ESCAPED is passed to InstallExecuteSequence while DB_LOAD_DSN is not.
I can not figure out Windows Installer's logic, here.
