ybe
Why is my password changed during silent installer?
When i try to run a silent installation of my application through PowerShell, I can see in the install log that Advanced Installer adds spaces in my password.
I have a script with PowerShell commands through which I run the silent install. Before I pass the password parameter to the silent installer I Base64 encrypt the password:
So the original password: testing
Becomes this base64 encrypted password: dGVzdGluZw==
Because of the "==" in the end, the password passed to our Custom Action is "dGVzdGluZw= =". For some reason a space is added between the two "=".
Do you have any idea why this happens?
Re: Why is my password changed during silent installer?
Could you please let me know what Advanced Installer version you are using?
I am asking this because I have reported a similar issue in the past and it has been fixed in version 17.2 of Advanced Installer:
Advanced Installer 17.2 Release Notes
The registry value is not correctly written in registries during silent installation
ybe
I'm using Advanced Installer 17.0
Could you please download a later version of Advanced Installer, retest this scenario and let me know if everything works as expected?
As mentioned above, this issue should have been fixed in version 17.2.
