HienHo
Website binding with a hostname
Hi AI,
I was trying to bind a published website with a host name to the local IP address (https://www.advancedinstaller.com/user- ... nding.html) so that when the installer is complete, it would launch http://www.test.com in the browser:
Below was my website binding from within AI:
Host name: www.test.com
Port number: 80
IP address: 127.0.0.1
And in the Custom Actions, I used OpenURL with the URL - http://www.test.com
But it didn't work (hostname was not being resolved).
Please advise. Thank you.
Hien
HienHo
Re: Website binding with a hostname
In addition to the below, would it be possible to assign the IP address to the IP address of the machine that it's installing from? Thanks.
Hien
Hello Hien,
When is the "OpenUrl" custom action scheduled?
Please note that your website is installed towards the end of the installation, therefore you need to schedule your custom action after that.
A solution to this could be adding the custom action without sequence and then triggering it from the "Finish" button from the "ExitDlg" dialog.
In order to achieve this, you can create a custom action that takes the IP address from the machine and then store it in a property. After doing so, you can use that property in the "IP address" field.
HienHo
Please find attached a sample aip that illustrates the attempt to assign a hostname to a local IP address and to launch the website when the install is complete. Could you please advise if I have missed out any crucial steps?
And how do I "...create a custom action that takes the IP address from the machine and then store it in a property"?
Thanks a lot in advance.
Hien
Deploy-Website.zip
(511.42 KiB) Downloaded 560 times
Hello Hien,
Thank you for the provided sample project.
When trying to launch a website that is installed locally, please note that the "hosts" file may also need to be updated with the IP binded to the hostname.
The computer file hosts is an operating system file that maps hostnames to IP addresses. It is a plain text file.
The hosts file can be found in the following location:
C:\Windows\System32\drivers\etc
hosts file.png (58.92 KiB) Viewed 8488 times
As you can see, now, after the installation, the binding is correctly done, despite the fact that there is a parsing error with the file (most likely, due to a missing resource on my machine).
Regarding this, some other users may also find this useful, therefore I will try to create a more comprehensive guide. Please give me some more time and I will update this thread as soon as the guide will be online.
HienHo
Thank you for your response. Much appreciated.
So I gather that Advanced Installer doesn't map a hostname with ip address during the install? And this step needs to be manually done?
Hien
Hello Hien,
Here is the article I have mentioned in my previous thread.
Local IIS Website - automatic IP assignment to Hostname
Hope that will be of help for you!
Advanced Installer does that.
However, in case of locally installed websites that are not available on the internet just yet , the "hosts" file will also need to me modified. Normally, a website that is available on the internet will have its hostname and ip address binding by the DNS.
You can find more information about this in the following StackOverflow thread:
Is DNS server And Host file Are different?
HienHo
Thank you very much Catalin for the detailed article and response. Awesome.
Hien
You are always welcome, Hien!
It is always my pleasure to help! :)
I have noticed your answer to my other thread. I will have a look over it soon and I will follow you up there.
