sandeep.gvn
How to add a Temporary Folder from Command Line
Could you please let me know "How to add a Temporary Folder through command line for AIP Projects"?
G.V.N.Sandeep
Re: How to add a Temporary Folder from Command Line
Hello Sandeep,
I am afraid your request is not quite clear to me.
If you meant to ask how to add a temporary file in your project through command line, please refer to our "Add Temporary File Command Option" article.
If that's not what you meant, please give me some more details so I can further assist.
sandeep.gvn
Hi Catalyn,
Here is my requirement.. There is a function in Advanced Installer called "Add Temporary Folder" as per the attached screen shot. I would like to know "How would I invoke the same function through command line"?
Regard,
Sandeep.
Temp Folder.png (622.23 KiB) Viewed 8857 times
Hello Sandeep,
Your scenario is now clear to me.
Unfortunately, we do not have such command.
I have added this on our TODO list of improvements and hopefully this will be added in a future version of Advanced Installer. Thank you for bringing this to our attention!
sandeep.gvn
Catalin, Thanks for the information and adding this as an improvement to your ToDo List.
I was able to get this to work somehow by making use of the command below
/edit "MyProject.aip" /AddFolder "TempFolder" "TEMP_FOLDER_01"
I am able to see the folder getting added to the the Temporary Folder which is located under windows section of Aip Project. But somehow at the time of installation, system is not able to copy this particular folder into Temp at the time of installation.
Do you have any work around for this, where the folder which gets added to Temporary Folder using the above commands gets copied into Temp Folder at the time of installation?
Sandeep.
Hello Sandeep,
First of all, please accept my apologies for the delayed reply (I was off last week due to not feeling well).
Please note that the "workaround" you have found does not really achieve the same as using the "Add temporary folder" option.
When using the "Add temporary folder" option, all the files from the selected folder are added as temporary files, whereas with your "workaround" they are added as normal files.
I have tested this and everything worked as expected on my end - the folder was added under the %temp% folder at install time:
Please make sure that you have enough rights to write to the %temp% folder.
Hello Sandeep,
This improvement has been added in Advanced Installer 19.9, released on September 14th, 2022.
