IanB
Multiple Folders
Can anyone explain if it is possible, and how, to install files in multiple folders that are at the same level. For example, if I have two folders, C:\A1\DEF\ and C:\B1\XYZ\ and I need to install files in both DEF and XYZ, is that possible with Advanced Installer? I can't find any way to add the folder B1 to the GUI at the same level as A1.
Re: Multiple Folders
Hi Ian,
You can achieve this by creating the desired folders in the "Files and Folders" page of your project (see the image below).
You can also create "property-based folders" and set the desired path for them.
Let me know if this helped, otherwise give me more details about your scenario.
Create Folders.png (11.93 KiB) Viewed 14103 times
