markoc
Setting up a IIS reverse proxy - ARR support
We are trying to set up a IIS reverse proxy using the IIS component of the Advanced Installer. One of the problems we are facing is trying to set up Application Request Routing (ARR) in order to enable proxying of requests from our public endpoints to our private ones.
The only place where this seems doable is inside the "Custom properties" tab of a website we create. There we create 4 new IIS Attributes with Attribute ID Section set to system.webServer/proxy and with Attribute ID Name and Value set to what is needed (enabled="True"; xForwardedForHeaderName="X-Real-IP"; reverseRewriteHostInResponseHeaders="False"; includePortInXForwardedFor="False").
Also, we need to configure URL Rewrite as well and, again, the only place where this seems doable is inside the "Custom properties" tab of the website. After setting those and building our project, we proceed to run the built installer. The installation unfortunately fails with a weird COM error while trying to set the system.webServer/proxy attributes.
So, my question is: Is there support for ARR in Advanced Installer?
Re: Setting up a IIS reverse proxy - ARR support
Unfortunately, I can not say for sure whether we have support for ARR or not.
Please give me some more time to further investigate this and maybe consult with our development team and I will followup this thread as soon as I will reach a conclusion.
I have further investigated this with our development team and it looks like we do not currently support Application Request Routing in our IIS module.
I have added this on our TODO list of improvements and we will try to implement this in a future version of Advanced Installer.
Once this will be added, I will update this thread.
markoc
Thank you for your response, I am looking forward to the update.
Kind regards,
Marko
You are always welcome, Marko!
Fazlur Shaikh
Hi Team,
Can you confirm which version has ARR support it?
Thanks.
-Fazlur.
Hello Fazlur,
I'm afraid this is still on our TODO list.
It has been assigned a lower priority due to limited demand from our users.
I have now increased its priority and hopefully this will be implemented in a future version of Advanced Installer.
We will update this thread as soon as this improvement will be added to Advanced Installer.
