johnfredmeyer@me.com
SQLServerConnectionDlg Question
Wed Jun 02, 2021 8:49 pm
Is there a way to setup so that it doesn't use a combobox and person installing has to manually type the name of the server in the sqlserverconnectiondlg?
Re: SQLServerConnectionDlg Question
Fri Jun 04, 2021 5:28 pm
Not quite sure why you would like to do that, but you could proceed in two ways here:
1. use the "SQLConnectionDlg" dialog instead of the "SQLServerConnectionDlg" dialog.
However, by doing so, you will need to do everything manually. More information about this can be found in the following article:
Configure MS-SQL Server Connection
2. remove the "Combobox" control and replace it with an "Editbox" control, as it is for the "Username" and "Password", for example.
