ccernat
Run SQL Script only when upgrading
Fri Jun 11, 2021 1:04 pm
Hello!
I in a bit of a problem. After reading the resources available here, I cannot determine why some SQL script are not running when upgrading older products.
I have 2 SQL scripts that I need to run when the process is an upgrade process. One of them creates a databases and its tables and another runs a stored procedure.
My setup looks like in the image bellow:
What should I do to have those 2 yellow marked script to run when upgrading?
Tks a lot!
Re: Run SQL Script only when upgrading
Fri Jun 11, 2021 4:48 pm
Hello Catalin and welcome to our forums,
From what I can see in your screenshot, you have conditioned the SQL script with the UPGRADINGPRODUCTCODE property.
There are two properties that are set during an upgrade, namely:
- UPGRADINGPRODUCTCODE
- OLDPRODUCTS
As you may already know, the upgrade process consist of two steps:
- the uninstall of the older version
- the install of the newer version
The difference between these two properties consist of where they are set, i.e.:
- UPGRADINGPRODUCTCODE will be set in the uninstalled package
- OLDPRODUCTS property will be set only in a package that upgrades another package (i.e. the newer version)
Assuming you want to execute the SQL script when your new version is installed, please condition it with the OLDPRODUCTS property instead.
