leapold
Selected language in the custom action
I would like to get user selected language from the combo box in the custom action( c# code).
How can I?
Re: Selected language in the custom action
In order to achieve that, you could proceed as it follows:
- retrieve, in your custom action, the ProductLanguage Property
How to set an installer property using custom actions
- based on its' value, display the message in the specified language
leapold
Hi.
I am running exe (console app C# project).How can I get session?
leapold
Should I set property inside installer? Is it possible to get demo example?
This might be a little bit more complicated then.
I thought you were using a C# custom action (DLL)
This is still possible to achieve, though.
First of all:
No, the ProductLanguage property is automatically set according to the setup's language. For more information, please see the article I have linked above.
Here is how you could proceed in your scenario:
- create a .TXT file containing the language of your setup through a "Text file update" operation, e.g.:
The above should create, after the installation, a file similar to this:
- read, from that .TXT file, the code and based on it, display the message in the required language - this should be done from your custom action's code
This will work if your custom action is scheduled after the "Add resources" action group and with its' "Execution Time" set to "When the system is being modified (deferred)".
The reason behind this is the fact that the text file update operation executes on a component install, which executes during the "Add resources" action group.
leapold
I hope I describe good what I want to reach. The language is going to be selected from installation package.
The custom action with c# code it is last step.
leapold
I can't add New Text File Update. This option is available only for Enterprise edition. Can I add text file instead?
Also where is Edit text file Update?
The "Text file update" is indeed available starting with our Enterprise suite.
Unfortunately, the simple text file will not help here, because we need it updated with the language code.
Another solution would be using the "Registry" page to store the language code in the registry. You can then read the value from the registry entry in your custom action.
leapold
I added new key [RV] but after installation I can't find registry and value.
Where should I see it in the registry editor?
If your installation type ("Install Parameters" page) is of "per-machine" type, there are two locations:
win+R --> type regedit.exe
- HKEY_LOCAL_MACHINE\SOFTWARE\Your_Manufacturer\Product_Name\[RV]
- HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Your_Manufacturer\Product_Name\[RV] --> if the package is 32-bit installed on a 64-bit machine
