Greetings,
AI is great product. Thanks for the good work. But I'm kind of stuck
right now.
I was running a (registered!) version of AI 2.4.? and then upgraded to 2.5.1.
At the same time I changed versions of Java on my two build systems and now whenI run AI on either the build fails with this error message:
"Creating CAB file(s)... Exception - Reason: Error opening file:
C:\Program Files\Caphyon\Advanced Installer\aijcl.exe."
When I try to execute that file by clicking on C:\Program
Files\Caphyon\Advanced Installer\aijcl.exe I get a Windows error message:
"Java Class Path was not specified in INI file."
I assume this relates to the Java version change, but don't know how to
fix it.
Any help appreciated, thanks!
Oliver Moffat
