Hello Tom,
Unfortunately, this is a limitation of Windows Installer (the core technology that Advanced Installer uses).
You can read more about this here:
ProductVersion Property
Note that Windows Installer uses only the first three fields of the product version. If you include a fourth field in your product version, the installer ignores the fourth field.
We recently added an improvement regarding this on our TODO list (i.e. to allow the user to perform a major upgrade using the 4th field of the
ProductVersion property) and I believe it might be available in our next release.
In the meantime, a solution to this is presented in the following thread:
Can't upgrade with 4-part product versions
