Codename K
SFTP Downloads?
Can Advanced Installer download files from SFTP during the installation process?
K
Re: SFTP Downloads?
Hello K,
I do not think we have built-in support for this, but most likely that is achievable through a Custom Action.
Currently, our "File Download" operation only supports "http", "https" and "ftp", if the documentation is up to date.
You could try that using a "sftp" link and see if that works.
Codename K
Re: SFTP Downloads?
Thanks for you answer.
Do you mean like using VBScript in Custom Action?
K
Re: SFTP Downloads?
Hello K,
Yes, it can be anything to be honest - VBS, PowerShell, C#.
Before that, I would suggest trying our "File Download" operation first, perhaps that will save you from creating your own custom action.
Codename K
Re: SFTP Downloads?
Thanks for the information.
K
Re: SFTP Downloads?
You are always welcome!
Codename K
Re: SFTP Downloads?
Does the new version of Advanced Installer have a solution to download files from SFTP which also asks for username and password?
K
Re: SFTP Downloads?
Hello K,
I'm afraid this might not be possible with our predefined support.
Codename K
Re: SFTP Downloads?
It is OK, I understand. Will there be support in the future versions?
K
Re: SFTP Downloads?
Hello K,
Sure, I can add this on our TODO list of improvements.
However, until then, could you please give me some more details about your scenario so I can better understand it and forward it to our dev team?
Codename K
Re: SFTP Downloads?
Thank you.
The installer needs to download files in SFTP. For example, sftp.example.com/myfile. You also need to enter a username and password to access the files in SFTP. This SFTP link does not directly point to the file. It is not sftp.example.com/myfile.zip, just sftp.example.com/myfile.
K
Re: SFTP Downloads?
Thank you for your followup on this and for sharing the scenario's details with me!
On our "File Download" article, it mentions that:
For resources that need authentication the format should be : protocol://username:password@DomainOrIP:port/path/filename
Example : https://username:password@example.com
Have you tried setting it like that?
Codename K
Re: SFTP Downloads?
Thanks. I tried this one,
https://username:password@sftp.example.com
But, I got this error message,
The URL is invalid.
K
Re: SFTP Downloads?
Hello K,
I will add this on our TODO list of improvements and I will update this thread when this will be implemented.
Codename K
Re: SFTP Downloads?
Thank you.
K
