vsb16
Change the order of edit controls on custom dialogs.
We have a custom dialog having edit controls.
The order of the edit control is changed means when we are in the first edit control and press the tab it goes to 3rd edit control instead of the second.
How can we rearrange the order of control using an advance installer?
Thank you!
Re: Change the order of edit controls on custom dialogs.
For that you can use the "Edit" toolbar button:
edit order.png (69.32 KiB) Viewed 1564 times
Just click on the "Edit" --> "Edit in dialog" option and the "Control Tab order" dialog will be displayed.
