In order to close your application, you can use the
"Auto-close application" operation.
Regarding this:
When you call the updater am I just calling the updater.exe or am I having some code run so its a silent install?
I am not sure I fully understand your scenario. Could you please give me some more details?
Are you trying to install the updates silently? If that is the case, then you can pass the silent command line for your MSI/EXE in the
"Command Line" field from the
"Update Installer" tab:
- CommandLine.png (35.12 KiB) Viewed 1525 times
