ogelfond
Display current progress action in one line
I'm trying to add Installation Progress text to Progress dialog. I originally followed this tutorial: https://www.advancedinstaller.com/user- ... mmary.html
It works fine, but the text in the text box is not rendering clearly (it's blinking every half a second or so) and I would like to display only currently performed action in one line and just update that one line text box with the most recent action from the log. Is it possible to do? I would also like to use regular Static Text control instead of mulitline edit box since it allows transparent background.
Re: Display current progress action in one line
That happens because you might used the "Display action text during install" event. This is like the default one located on "Status:"
You can also follow the steps from the tutorial and use a "Static Text" control. But keep in mind that the text will be displayed one below the other when using the "Display installation actions summary" event.
To change the current row you need to use the "Display action text during install" event, but this will "blink" as you said because the installation moves faster to the next event. This will be visible long enough on operations such long custom actions (PowerShell scripts, writting to registry, etc.).
ogelfond
Got it. Thank you for prompt reply!
You're welcome!
