JasonZhang
How to set a variable install folder?
I need to create a new installer which install folder path depends on a registry value.
How to get the registry value and set it to the install path?
Many thanks.
Jason
Re: How to set a variable install folder?
Hello Jason and welcome to our forums,
You can achieve this using a registry search and then set the APPDIR to the value returned from the search.
1. Go to the "Registry" page and create a registry search location.
For more details you can see our How to create a Registry Search article.
2. From the "Custom Actions" page you can add a "Set installer property" custom action scheduled after "Searches" action group in the Wizard Dialogs Stage.
set property.png (178.7 KiB) Viewed 2607 times
If you do not want to allow the user to change the installation path then you can remove the "FolderDlg" dialog from the "Dialogs" page.
Hope this helps! Please let me know if you have any questions.
DanielleFredericksn
Last edited by DanielleFredericksn on Fri Jul 08, 2022 9:20 am, edited 2 times in total.
Hello Danielle and welcome to our forums,
In order to achieve that, you can use our "Environment Variable" page.
