prince21
SQL Script & Installation
Step1 : Enable .net framework packages
Step2 : if( Exist(SQL Express 2019) { run Script (Window Authentication) ) }
Else { install SQL Express 2019 and run Script (window Authentication) }
Step 3 : configure IIS => Deploy Code
Actually i perform point 1 & 3 ..
mainly unbale to do point no. 2 >>>
please help me for point number 2 only
Re: SQL Script & Installation
In order to achieve this, you can add your SQL Express 2019 as a pre-install prerequisite in the Prerequisites page. You can condition its installation on the "Install Conditions" tab.
We already have the predefined "SQL Server Express 2019" prerequisite. If this version is not present on the target machine, then it will be installed before your main package.
From the "SQL Databases" page you can add your desired scripts.
